MESA-LOADER: failed to open iris (search paths /snap/hydralauncher/x1/gnome-platform/usr/lib/x86_64-linux-gnu/dri)
failed to load driver: iris
MESA-LOADER: failed to open kms_swrast (search paths /snap/hydralauncher/x1/gnome-platform/usr/lib/x86_64-linux-gnu/dri)
failed to load driver: kms_swrast
MESA-LOADER: failed to open swrast (search paths /snap/hydralauncher/x1/gnome-platform/usr/lib/x86_64-linux-gnu/dri)
failed to load swrast driver
MESA-LOADER: failed to open nouveau (search paths /snap/hydralauncher/x1/gnome-platform/usr/lib/x86_64-linux-gnu/dri)
failed to load driver: nouveau
A JavaScript error occurred in the main process
Uncaught Exception:
Error: /lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /snap/hydralauncher/x1/resources/app.asar.unpacked/node_modules/classic-level/build/Release/classic_level.node)
at process.func [as dlopen] (node:electron/js2c/node_init:2:2559)
at Module._extensions..node (node:internal/modules/cjs/loader:1602:18)
at Object.func [as .node] (node:electron/js2c/node_init:2:2786)
at Module.load (node:internal/modules/cjs/loader:1295:32)
at Module._load (node:internal/modules/cjs/loader:1111:12)
at c._load (node:electron/js2c/node_init:2:16955)
at Module.require (node:internal/modules/cjs/loader:1318:19)
at require (node:internal/modules/helpers:179:18)
at load (/snap/hydralauncher/x1/resources/app.asar/node_modules/node-gyp-build/node-gyp-build.js:22:10)
at Object.<anonymous> (/snap/hydralauncher/x1/resources/app.asar/node_modules/classic-level/binding.js:1:43)
[53652:0514/205249.810775:ERROR:wayland_connection.cc(197)] Failed to connect to Wayland display: No such file or directory (2)
[53652:0514/205249.810806:ERROR:ozone_platform_wayland.cc(264)] Failed to initialize Wayland platform
[53652:0514/205249.810809:ERROR:env.cc(258)] The platform failed to initialize. Exiting.
fish: Job 1, 'hydralauncher --no-sandbox' terminated by signal SIGSEGV (Address boundary error)Hydra launcher ошибка при запуске libstdc++.so.6: version `GLIBCXX_3.4.29' not found
Всем привет. Я хотел запустить Hydra launcher (зеленный стим). Загрузил сначала AppImage. Программа запускается, но когда пытаешься скачать репак игры и нажимаешь кнопку "Загрузить сейчас" ничего не происходит (источники загрузок выставил). Просто ничего не происходит. Решил установить версию snap. При попытке запуска Hydra launcher возвращает ошибку . Я новичок в linux и в ARCH прошу помогите
- medusaLLLL
[ЕСЛИ ВСЕ ЕЩЕ АКТУАЛЬНО]
1. Обновить систему:
2. Установить или переустановить нужные драйверы:
3. Убедиться, что libstdc++ актуальна:
4. По возможности избегать Snap:
Snap в Arch — не лучшая идея. Используй:
AUR (yay -S hydralauncher, если есть)
Flatpak (более нативно поддерживает sandbox и shared libs)
AppImage — часто можно просто скачать и запустить без зависимости от окружения.
sudo pacman -Syu# Intel
sudo pacman -S mesa vulkan-intel
# NVIDIA (proprietary)
sudo pacman -S nvidia nvidia-utils
# Nouveau (открытый драйвер)
sudo pacman -S xf86-video-nouveausudo pacman -S gcc-libsSnap в Arch — не лучшая идея. Используй:
AMD Ryzen 7 5800X 8-Core Processor × 8 | Advanced Micro Devices, Inc. [AMD/ATI] Navi 23 [Radeon RX 6600/6600 XT/6600M] | X11
