Дефектные обновления [Core], [Extra]
VyacheslavS
vall: система с KDE перестала выходить из режима сна. Аналогичное поведение и на lts-ядре.
Тёмный экран монитора, -- и только кнопка reset системного блока позволяет вновь получить контроль над десктопом.
Подтверждаю, весь день только и занимаюсь нажатием кнопки reset.
vall:GPU: NVIDIA GeForce GTX 1050 Ti [Discrete]
[ 2395.216137] PM: suspend entry (deep)
[ 2395.253101] Filesystems sync: 0.036 seconds
[ 2395.284617] Freezing user space processes
[ 2395.286943] Freezing user space processes completed (elapsed 0.002 seconds)
[ 2395.286947] OOM killer disabled.
[ 2395.286948] Freezing remaining freezable tasks
[ 2395.287904] Freezing remaining freezable tasks completed (elapsed 0.000 seconds)
[ 2395.287919] printk: Suspending console(s) (use no_console_suspend to debug)
[ 2395.317967] sd 2:0:0:0: [sdc] Synchronizing SCSI cache
[ 2395.318022] sd 1:0:0:0: [sdb] Synchronizing SCSI cache
[ 2395.318725] ata2.00: Entering standby power mode
[ 2395.318771] ata3.00: Entering standby power mode
[ 2395.321316] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 2395.323176] ata1.00: Entering standby power mode
[ 2395.714288] ACPI: PM: Preparing to enter system sleep state S3
[ 2395.714472] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 2395.715021] ACPI: PM: Saving platform NVS memory
[ 2395.715178] Disabling non-boot CPUs ...
[ 2395.717516] smpboot: CPU 1 is now offline
[ 2395.719737] smpboot: CPU 2 is now offline
[ 2395.722027] smpboot: CPU 3 is now offline
[ 2395.724515] smpboot: CPU 4 is now offline
[ 2395.726350] smpboot: CPU 5 is now offline
[ 2395.728942] smpboot: CPU 6 is now offline
[ 2395.730753] smpboot: CPU 7 is now offline
[ 2395.737402] ACPI: PM: Low-level resume complete
[ 2395.737419] ACPI: PM: Restoring platform NVS memory
[ 2395.737499] LVT offset 0 assigned for vector 0x400
[ 2395.742903] Enabling non-boot CPUs ...
[ 2395.743221] smpboot: Booting Node 0 Processor 1 APIC 0x11
[ 2395.751630] ACPI: \_PR_.P002: Found 2 idle states
[ 2395.751875] CPU1 is up
[ 2395.752138] smpboot: Booting Node 0 Processor 2 APIC 0x12
[ 2395.762257] ACPI: \_PR_.P003: Found 2 idle states
[ 2395.762514] CPU2 is up
[ 2395.762782] smpboot: Booting Node 0 Processor 3 APIC 0x13
[ 2395.772294] ACPI: \_PR_.P004: Found 2 idle states
[ 2395.772597] CPU3 is up
[ 2395.772870] smpboot: Booting Node 0 Processor 4 APIC 0x14
[ 2395.782329] ACPI: \_PR_.P005: Found 2 idle states
[ 2395.782654] CPU4 is up
[ 2395.782901] smpboot: Booting Node 0 Processor 5 APIC 0x15
[ 2395.792365] ACPI: \_PR_.P006: Found 2 idle states
[ 2395.792730] CPU5 is up
[ 2395.793001] smpboot: Booting Node 0 Processor 6 APIC 0x16
[ 2395.802374] ACPI: \_PR_.P007: Found 2 idle states
[ 2395.802755] CPU6 is up
[ 2395.803002] smpboot: Booting Node 0 Processor 7 APIC 0x17
[ 2395.812472] ACPI: \_PR_.P008: Found 2 idle states
[ 2395.812921] CPU7 is up
[ 2395.822827] ACPI: PM: Waking up from system sleep state S3
[ 2395.836870] usb usb8: root hub lost power or was reset
[ 2395.836875] usb usb9: root hub lost power or was reset
[ 2396.121338] usb 8-1: reset high-speed USB device number 2 using xhci_hcd
[ 2396.307972] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2396.308002] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2396.308698] sd 0:0:0:0: [sda] Starting disk
[ 2396.308726] sd 1:0:0:0: [sdb] Starting disk
[ 2396.308829] ata1.00: configured for UDMA/133
[ 2396.308855] ata2.00: configured for UDMA/133
[ 2396.631165] OOM killer enabled.
[ 2396.631167] Restarting tasks ... done.
[ 2396.638865] random: crng reseeded on system resumption
[ 2396.638876] PM: suspend exit
Без проблем.
Продолжаем обсуждение здесь viewtopic.php?t=3157
SmiGes
Где-то с месяц назад началась проблема с пакетом gdk-pixbuf2 . Заметил так: использую DE Mate, перестали сохранятся скриншоты (при этом при сохранении скриншота в списке процессов стало появляться большое количество процессов bwrap.) Поискав в англоязычном форуме, увидел что люди там боролись с этой проблемой устанавкой пакета из AUR gdk-pixbuf2-noglycin (а сейчас ещё и второй надо пакет собирать librsvg-noglycin). Хотел спросить у всех такая проблема, или это только на mate проявляется?
SmiGes:у всех такая проблема, или это только на mate проявляется?
ХFCE - no problem). Всё отлично работает. Обновления последние.
из своего 5+ летнего опыта заметил закономерность.
повторяется ежегодно.
в период с 12 месяца и до первых чисел февраля попытки обновлений установок приводят к проблемам.
то есть, если нет срочности, лучше отложить,
на этот период использовать архивный или локальный репозиторий.
мое частное мнение, вполне могу ошибаться.
BendalfRU из своего 9+ летнего опыта ничего не заметил.
Если и бывают какие-то проблемы, то подробности сразу появляются на главной archlinux.org в новостях.
14янв2026 обновил,
Отзывчивость ПК значительно увеличилась, как-будто по смазке едет.
Благодарю.
valeracr
После последнего обновления:
[2026-05-22T06:19:26-0400] [ALPM] transaction started
[2026-05-22T06:19:27-0400] [ALPM] upgraded cmake (4.3.2-1 -> 4.3.3-1)
[2026-05-22T06:19:27-0400] [ALPM] upgraded fakeroot (1.38-3 -> 1.38.1-1)
[2026-05-22T06:19:27-0400] [ALPM] upgraded libopenmpt (0.8.6-1 -> 0.8.7-1)
[2026-05-22T06:19:27-0400] [ALPM] upgraded vapoursynth (75-2 -> 75-3)
[2026-05-22T06:19:28-0400] [ALPM] upgraded mesa (1:26.0.6-1 -> 1:26.1.1-2)
[2026-05-22T06:19:28-0400] [ALPM] upgraded firefox (150.0.3-1 -> 151.0-1)
[2026-05-22T06:19:28-0400] [ALPM] upgraded ghostscript (10.07.0-1 -> 10.07.1-1)
[2026-05-22T06:19:29-0400] [ALPM] upgraded haveged (1.9.21-1 -> 1.9.22-1)
[2026-05-22T06:20:15-0400] [ALPM] warning: directory permissions differ on /usr/share/hplip/base/__pycache__/, filesystem: 700 package: 755
[2026-05-22T06:20:15-0400] [ALPM] warning: directory permissions differ on /usr/share/hplip/base/pexpect/__pycache__/, filesystem: 777 package: 755
[2026-05-22T06:20:15-0400] [ALPM] warning: directory permissions differ on /usr/share/hplip/installer/__pycache__/, filesystem: 777 package: 755
[2026-05-22T06:20:15-0400] [ALPM] upgraded hplip (1:3.25.8-6 -> 1:3.26.4-1)
[2026-05-22T06:20:15-0400] [ALPM] upgraded lib32-mesa (1:26.0.6-1 -> 1:26.1.1-1)
[2026-05-22T06:20:15-0400] [ALPM] upgraded vulkan-mesa-implicit-layers (1:26.0.6-1 -> 1:26.1.1-2)
[2026-05-22T06:20:15-0400] [ALPM] upgraded lib32-vulkan-mesa-implicit-layers (1:26.0.6-1 -> 1:26.1.1-1)
[2026-05-22T06:20:15-0400] [ALPM] upgraded vulkan-radeon (1:26.0.6-1 -> 1:26.1.1-2)
[2026-05-22T06:20:15-0400] [ALPM] upgraded lib32-vulkan-radeon (1:26.0.6-1 -> 1:26.1.1-1)
[2026-05-22T06:20:15-0400] [ALPM] upgraded libheif (1.22.0-1 -> 1.22.0-2)
[2026-05-22T06:20:15-0400] [ALPM] upgraded opencl-mesa (1:26.0.6-1 -> 1:26.1.1-2)
[2026-05-22T06:20:15-0400] [ALPM] upgraded perl-http-daemon (6.16-6 -> 6.17-1)
[2026-05-22T06:20:16-0400] [ALPM] upgraded qt5-translations (5.15.18-1 -> 5.15.19-1)
[2026-05-22T06:20:16-0400] [ALPM] upgraded qt5-base (5.15.18+kde+r109-2 -> 5.15.19+kde+r96-1)
[2026-05-22T06:20:16-0400] [ALPM] upgraded qt5-declarative (5.15.18+kde+r23-1 -> 5.15.19+kde+r23-1)
[2026-05-22T06:20:16-0400] [ALPM] upgraded qt5-graphicaleffects (5.15.18-1 -> 5.15.19-1)
[2026-05-22T06:20:16-0400] [ALPM] upgraded qt5-imageformats (5.15.18+kde+r2-1 -> 5.15.19+kde+r2-1)
[2026-05-22T06:20:16-0400] [ALPM] upgraded qt5-multimedia (5.15.18+kde+r2-1 -> 5.15.19+kde+r2-1)
[2026-05-22T06:20:16-0400] [ALPM] upgraded qt5-networkauth (5.15.18-1 -> 5.15.19-1)
[2026-05-22T06:20:16-0400] [ALPM] upgraded qt5-quickcontrols (5.15.18-1 -> 5.15.19-1)
[2026-05-22T06:20:16-0400] [ALPM] upgraded qt5-quickcontrols2 (5.15.18+kde+r5-1 -> 5.15.19+kde+r5-1)
[2026-05-22T06:20:16-0400] [ALPM] upgraded qt5-script (5.15.19-3 -> 5.15.19-4)
[2026-05-22T06:20:16-0400] [ALPM] upgraded qt5-serialport (5.15.18-1 -> 5.15.19-1)
[2026-05-22T06:20:16-0400] [ALPM] upgraded qt5-speech (5.15.18+kde+r1-1 -> 5.15.19+kde+r1-1)
[2026-05-22T06:20:16-0400] [ALPM] upgraded qt5-svg (5.15.18+kde+r5-1 -> 5.15.19+kde+r5-1)
[2026-05-22T06:20:17-0400] [ALPM] upgraded qt5-tools (5.15.18+kde+r3-2 -> 5.15.19+kde+r3-1)
[2026-05-22T06:20:17-0400] [ALPM] upgraded qt5-wayland (5.15.18+kde+r55-1 -> 5.15.19+kde+r55-1)
[2026-05-22T06:20:17-0400] [ALPM] upgraded qt5-x11extras (5.15.18-1 -> 5.15.19-1)
[2026-05-22T06:20:17-0400] [ALPM] upgraded qt5-xmlpatterns (5.15.18-1 -> 5.15.19-1)
[2026-05-22T06:20:17-0400] [ALPM] upgraded ripgrep (15.1.0-2 -> 15.1.0-3)
[2026-05-22T06:20:17-0400] [ALPM] upgraded semver (7.8.0-1 -> 7.8.1-1)
[2026-05-22T06:20:17-0400] [ALPM] upgraded wget (1.25.0-4 -> 1.25.0-5)
[2026-05-22T06:20:17-0400] [ALPM] upgraded xfsprogs (7.0.0-1 -> 7.0.1-1)
[2026-05-22T06:20:18-0400] [ALPM] transaction completed
Opera и Chrome выглядят вот так:
В Firefox все норм.
Может кто сталкивался и подскажет что?
opera и haveged откатывал.
ps Вот, тоже тему открыли:
https://bbs.archlinux.org/viewtopic.php?id=313636
Посмотрим.
valeracr
О, там по ссылкам нашел как временное решение:
opera --use-angle=opengl -use-gl=egl
fontconfig не обновлялся. По-прежнему версия :
pacman -Qs fontconfig
local/fontconfig 2:2.17.1-1
Сейчас обновился и глянул Chromium -- всё нормально. Opera не установлена. Может быть Opera и "наследила" (умозрительная версия).
❯ pacman -Qs fontconfig
    Library for configuring and customizing font access
local/lib32-fontconfig 2:2.17.1-1
На bbs речь идёт о версии 2:2.18.0-1. https://bbs.archlinux.org/viewtopic.php?id=313631
valeracr
GoogleEarth тоже корежило. И шрифты и в режиме просмотра улиц:
Помог откат mesa и opencl-mesa из последнего обновления до версии 1:26.0.6-1
И опера и chrome теперь все ок.
beisic
valeracr: Помог откат mesa и opencl-mesa из последнего обновления до версии 1:26.0.6-1
На ноутбуке ,после обновления , тоже так же получил кракозябры шрифтов. Помогла команда :
pacman -U https://archive.archlinux.org/packages/ ... kg.tar.zst
На стационарном ПК при обновлении обошлось без кракозябр.
Эта "беда" , что только ноутбуков коснулась ??
valeracr
beisic:Эта "беда" , что только ноутбуков коснулась ??
Да нет, у меня именно на стационарном артефакты были.
Причина, скорее всего , во взаимодействии какого-то установленного софта с этой версией mesa.
valeracr
Обновление fontconfig приводит к краху telegram при старте.
error: empty dic file
Hash Manager Error : 2
QPainter::begin: Paint device returned engine == 0, type: 2
QWidget::render: Cannot render with an inactive painter
zsh: segmentation fault  Telegram
Помогает откат fontconfig до версии 2:2.17.1-1
https://github.com/telegramdesktop/tdes ... sues/30761
valeracr: Обновление fontconfig приводит к краху telegram при старте.
Нормально всё стартует.
Arhei
под sway тоже выдаёт эту ошибку но не крашиться и продолжает нормально работать:
$ pacman -Q sway telegram-desktop fontconfig
sway 1:1.12-1
telegram-desktop 6.8.2-4
fontconfig 2:2.18.1-1
$ Telegram
qt.waylandcompositor.hardwareintegration: Failed to initialize EGL display. There is no EGL_WL_bind_wayland_display extension.
valeracr
Да понятно, что дело не в wm, а в каких-то установленных шрифтах в системе, с которыми не дружит последняя версия fontconfig
Здесь еще обсуждают:
https://bbs.archlinux.org/viewtopic.php?id=313797
Обновление Chromium 153.0.8010.52-1 -> 154.0.8037.97-1 привело к неработоспособности браузера. Откат решил проблему в моём случае. KDE.
